Zipfrog2022
New User
- New Jersey
- Automation Tech / Authroized Service Center
If 120VAC was applied to a 24VAC coil would this create a short between neutral and the hot leg secondary side of a 120VAC power supply “ 480VAC step-down transformer to 120VAC? If so would this likely blow fuses on the primary side of the transformer and cause 110VAC boards to fry? The arc marks and burning on this board stack looks like there was a dead short to the grounded mounting bracket for the board stack that then arced between the mounting bracket and three of the boards in the stack. Several components on the boards have blown and there are burn marks across the boards in the same area of the board stack mounting bracket. I have found no bare exposed wires and have gone through all the wiring to confirm everything is landed in the correct locations. The only thing I have found in this control head is that someone installed a reversing contactor with 24VAC coils when it should have been 120VAC coils.
Any thoughts on this would be appreciated. I’m just not sure if such a high overvoltage would actually cause a short between the two sides to cause all this damage or if the coils would have just burned up.
The other thing is my primary fuses “480VAC side blew not the secondary fuses on the 110VAC side of the power supply. One is extremely burned inside the other actually must have exploded charred glass fragments from the fuse were all over the inside of this control head.
Thanks
Thanks
