aftershock
- Memphis, TN
AC circuit is in a sub panel which is fed from the main panel where the arc fault circuit is.
Sub panel fed with a neutral and also has an arc fault circuit which does not trip.
The AC has an issue which when the contactor kicks in, it trips the 2 pole breaker that controls it, and also causes the arc fault in the main panel to trip.
Eaton brand.
Eaton brand.
