Re: AC control wiring
domnic,
You have the 600v wire rating covered if it's UL listed for the application. As long as you protect the control circuit as would normally be done there are no other provisions that you have to provide.
The only caution is that interference may be induced into the control wiring form the power conductors. With some electronic control there is a possibility that it may not work correct which often times can be address with a small modification if it is a problem.
Dave
