richxtlc
 - Tampa Florida
Depending on the CT is does care. Emon Demon CT's only work if you install them in one direction
I don't know what an emon demon ct is, but a ct connected to a relay or an ammeter is a magnitude measuring device. It does not care what direction the current is flowing. If you want directionality, you must provide either a reference voltage or reference current for the relay to determine the proper direction. Wattmeters, varmeters, all work on the relationship between the current and voltage and the direction of current thorugh the ct. The polarity marks on the ct only matter when directionality is important.
