What voltages are you asking about? What physical size do you need?Which manufacture and model makes dual rated breakers? Is it the Square D QUO series? Any others worth mentioning?
48 up to 400 volts, solar PV stuff. Currents up to 100 ampsWhat voltages are you asking about? What physical size do you need?
Are you looking for panelboard mounted units or lug-in lug-out designs?48 up to 400 volts, solar PV stuff. Currents up to 100 amps
