AC equipment/low voltage lighting
NYHigh
1)How far do residential condensors have to be from a gas meter.
2)Within how many feet should a receptacle be from condensor eqipment?
3)Is it still permissable to (run low voltage wire in the walls?) for low voltage under cabinet kitchen lighting?
4)How should a laundry room with countertop be treated according to code?
-Is it necessary to treat it like a kitchen countertop as far as spacing receptacles?
-Is 12 guage necessary?
-Is it necessary to be a dedicated circuit?
probably a local rule, not in the nec
25 ft
yes, use a chapter three method
no
20 amp circuit is necessary
yes
Care to take a stab at answering your own questions?
I could use some mod squad help to delete/edit my prior post in this thread.
I can't seem to find that darned EDIT lever :D
editing for the schooling of the op
