AC formulae and power analysis etc
pg1995
New member
California
Hi
Is my categorization of complex power S into phasor form, polar form, and rectangular form correct? Did I miss any category? Thank you for your help.
attachment.php
The first and the second line formulae are correct.
The third line result has to be: P=Vrms^2*R/(R^2+X^2) and Q=Vrms^2*X/(R^2+X^2) since: (R-jX)*(R+jX)=R^2+X^2
He did not need to use the conjugate for S = v^2/Z[/QUOT
IEEE Std 1459-2010, IEEE Standard Definitions for the Measurement of Electric Power Quantities Under Sinusoidal, Nonsinusoidal, Balanced, or Unbalanced Conditions. 3.1.1.3 Reactive power (var)
“NOTE 1— If the load is inductive, then Q > 0. If the load is capacitive, then Q < 0. This means that when the current lags the voltage θ > 0 and vice versa.”
Using Z=R+jX instead of Z*=R-jX the resulted Q<0 [capacitive].Usually X is inductive.
Yes he did!
Actually, the resulting Q2 is always positive, allowing Q to be either positive or negative.
If you do simple complex multiplication without the conjugate you get a negative value for
q2, which is impossible, and you get cross terms which still contain j, also unphysical for power.
Hi
attachment.php
Nice cut and paste job (twice) but what point were you, the OP, endeavouring to make?
Yes he did!
incorrect
Xc = -j
Xl = j
the sign convention for reactance takes care of that
