SCALDWELL
New member
- Dacula, GA
I am going to need to attach a simple AC power cord (NEMA 5-15P to standard ROJ power cord P/N 10W1-10106) which is a simple basic commercial off the shelf / COTS 3 wire 18 gauge power cord. I am going to attach this power cord to a Cisco power supply model PWR-IE50W-AC. It has a 3 screw terminal barrier strip with a clear plastic cover over it for safety. My question simply is this, am I required (by the UL/NFPA/NEC codes) to install a ring / spade terminal (using the approved crimp tool to install the ring terminal) onto the ends of the stripped wires before installing them under the screws on the terminal barrier strip? The only other way would be to wrap the (pre-tinned) stranded copper wire under the screws and tighten. Please let me know if you can help me answer this question or point me in the right direction as far as where this is specifically covered in the regulations / codes. Many thanks!
