GerryB
- woodbridge, ct. USA
My customer called late summer that at times a breaker would trip and the ac would go off .At the time I checked it quick and saw the pump was wired off the attic circuit j-box with other cables. It didn't trip all the time so today I went to investigate more. She has a 230v attic air handler. This breaker does not trip. The condensate pump was 120v so they had tapped an existing circuit for that outlet. The pump had the low voltage switch leads on it, these went thru a water alarm that was on the drip pan. So I'm thinking since only the 110 circuit trips and not all the time that there is something wrong with the pump or the alarm. I got rid of the 110v, changed the outlet to 240 and bought a new pump and plugged it in. Also it had the leads for the alarm. My question is when I got home I tested the old pump and it seems to work fine. It worked with the switch leads open or closed (should that happen?) So know I don't know what tripped her breaker.
