AC split Unit Disconnecting Switch
Mostafa
Certified Electrical Inspector - Code Enforcer
Egypt
I am wondering if it is allowed by the NEC not to install a disconnecting switch for the AC split unit if the split unit is energized from a panel board location in the same room insight with the AC unit itself?.
thanks
acrwc10
Master Code Professional
CA
Building inspector
thanks
Yes.
Dennis Alwon
Chapel Hill, NC
Retired Electrical Contractor
If I remember correctly there is no need for a disconnect for the inside unit as it is part of a package system. The disconnect outside should suffice.
