chateau mike
i have a unit with a minimum circuit ampacity of 23 amps, and maximum fuse of 35 amps. i come up with 28.75 amps (23x1.25). based on that calculation, #10 wire with a 30 amp disconnect and a 30 amp breaker should suffice. my supervisor believes a 60 amp switch with 35 amp fuses 30amp breaker and #8 wire should be used. this appears to be a gray area with un clear interpretations from the code book and training. :-?
