Access control panel circuit
Tainted
New York
Engineer (PE)
Does the access control panel need to be on a generator via a life safety panel? If it fails safe does it really matter? Before I had my PE I used to work with engineers that used to do this but now I'm questioning it
Tainted
New York
Engineer (PE)
You could make a case either way. "Fail Safe" isn't so safe when bad guys can access your building just by killing power.
Building code here says you must ensure all doors open when there is no power. So I think building code just wants to make sure people get out and the fire department can get in.
Tainted
New York
Engineer (PE)
Does "When there is no power" mean "when you're on generator?"
It reads "Loss of power to the lock or locking system shall automatically unlock the doors."
found in NYC building code1010.1.9.8 Sensor Release of Electrically Locked Egress Doors
doesn't say anything about what source of power
JoeStillman
West Chester, PA
I think it's saying more about the lock than the power supply. To me, it just means you can't have fail-secure locks. You can still have a fail-safe lock and be on backup power.
Tainted
New York
Engineer (PE)
Yea but what my question is really about is which of the 700, 701, 702 loads does the access control panel fall under?
JoeStillman
West Chester, PA
I would put it on the life safety panel. It's necessary for the safety and security of the occupants. Hook it up to an output from the fire alarm system that unlocks all the doors.
Don't forget that most access control systems have at least a few hours of battery power* or at least any responsibly-installed ones do.
*and often that's not a single battery but they're spread over all the different electronics boxes. They also probably haven't been replaced often enough :LOL:.
