Access door behind service panel?
eugenek
New member
Deleted
I'm finishing a DIY ground-mount PV install. One remaining task is to connect the wiring to the main service panel. I haven't dealt with the service panel before so I have some open questions.
First of all, I can't get to any of the knockouts because the panel is embedded in the exterior garage wall. It seems that I have to tear out a big chunk of the drywall behind the panel. Which raises a question. Do I need to put drywall back afterwards, or can I install something like a wooden access door instead, to make any future modifications easier? Anything in the codes against that?
Secondly, what's the correct way to connect the service panel to the conduit? The conduit is 1" PVC and it will terminate at a conduit body about a foot from the panel, at which point wires (8 AWG THHN) go into the wall. Do I need conduit from that point to the knockout in the panel?
I am closing this thread, in accordance with the Forum rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
If I have misjudged the situation, if for example this project is related to your work, then send me a Private Message. If you can show me that I am wrong, and that you are a licensed electrician (or at least a licensed apprentice), then I will reopen your post, and offer an apology for the delay and inconvenience.
A reminder to all members, if you see a questionable post, feel free to report it by clicking the
button at the bottom left corner of the post.
