Dark Sparky
- USA
- Electrical Engineer
Question regarding condulet/wiring accessibility.
We have a building with both warm & cold rooms ? with insulated wall panels forming the walls between hot & cold rooms.
Our design includes RGS conduits passing horizontally through the wall, into the warm room, with an LB condulet, then turning vertically up the warm side of the wall. Two additional pieces of information:
We have a concern whether this meets the requirements of NEC 314.29 (NEC 2011) ? that the conduit body remain accessible.
Does the pipe insulation around the LB condulet violate 314.29?
Is the spray foam inside the condulet a code issue? (It?s maintaining the vapor barrier continuity of the wall system.)
If you feel that this approach can be improved, for code conformance, while still retaining the goals of the pipe insulation and spray foam, please describe how.
Thank you,
Jonathan
- The condulet, before being closed up, is filled with spray foam (after wiring is installed)
- The LB (condulet) and adjoining conduit on both sides of the wall is wrapped in pipe insulation.
Thank you,
Jonathan
