Re: Accessible
Zachy,
Tell me if I'm wrong, but I'm reading that you "had" access to your cables thru a 1'x 4' flanged fixture flush mounted in a sheetrock ceiling. Now the 1'x 4' fixture is surface mounted, so you lost your access. Is this correct?
I don't see where the definition of 'accessible' prohibits the removal of a light fixture to access your cables. In the same breath, I don't think it's a good idea to remove light fixtures, sheetrock or lay-in, to access anything (wires should have been in conduit across sheetrock ceiling).
I agree with Steve that you may do this, simply because I don't know where it says you can't. Maybe someone will come on here and state a rule where this is not allowed (I'm interested also). Until then, you need a change order. Or like Chicar said, have 'them' install access panels.
Brent [/QB][/QUOTE]
