Just wanted to get a little input. Is it permissible to run a multiwire branch circuit to two accessory sheds about 50 ft from each other? Each shed would have a single toggle for a disconnect mounted outside on the shed. Reason for doing it this way is one for voltage drop and two I’m limited to space in the panel. Each shed will have 2 fans for horse stalls. Total load for fans and lights would not be more the 6 amps per shed. As for grounding electrode I believe it’s not necessary because it falls under a single circuit being a multiwire fed from a 2 pole breaker with single hand tie. Any input would be appreciated!
