Shawn pavich
- Fresno ca
On a solar ground mount ,let's say plans specs say 17 degree tilt . lowest part of the tilt on the array is 18" from grade,on the high end it is 4'4"from grade, let's say there is gradual change in grade (slop) in past installs I allways made my 4'4" on the high end of the slop first that would be my starting point, if the slop is 12" at my last module I would be at 5'4"at the end of my array,never had a issue with doing it like that,tell this last job with the HOA (home owners association)they did not want it higher then what the plans said,thank God we did not have any mods on yet.I tried to get out of it,I had know answer for them when they said why couldn't I start the 4'4" height at the bottom of the slop so that instead of the array rising a foot it would drop a foot,my question is were is the proper spot to start my 4"4 at the high end of the slop are the low end of the slope are does it really matter thanks
