smoothops10
- FL
- EE
Details below but main question, has anyone successfully seen active harmonic filters on 480/277V 3phase system supplied from a WYW WYE utility transformer (not the more common delta-wye)?
I have a site with two MCCs, each with 300hp and 100hp VFDs. The drives are the older SqD Altivar 61 6-pulse with 3% line reactors.
Each MCC has two (2) 100A Accusine PCS active harmonic filters. All four units are inoperable.
V THD readings at <2%. I THD readings at 20%.
Utility transformer is WYE-WYE 1500kVA, 5.99%IZ.
All 4 accusine units are inoperable. No one knows why or if they were ever started up at all 10 years ago.
I recall hearing about a past job that had specified the accusine filter units and the electric supplier in the area was a small electric cooperative that had installed a Y / Y utility transformer. When the filters operated, significant noise or issues were injected back into the cooperative’s distribution system affecting other supplied customers. I don't have all the details. My understanding is the Δ primary windings trap much of the noise (3rd harmonics) from being injected back whereas the Y windings do not. The cooperative made the site turn the filters off and I do not believe a resolution was ever reached.
Maybe this site turned these off for the same reason? Thoughts appreciated.
