Is there or can anyone show me what the necessary codes for wiring an actuator-valve on chilled water using "S.O. Cord" from the actuator to the power supply.
Thanks in adavance.
I don't think Lenny will let you get away with anything out there.![]()
The actuators are being replaced in all the Mech/Plant rooms on site. The cord lengths are in most cases less than 2 feet from Actuator terminals to the j-box and are 0-10 VDC. All the cords currently installed are loose and have no supports, simply hanging from actuator to j-box.
I would like to know of text or code from the NEC or NFPA to accompany the new valves and abide by what rules are in place.
Thank you all for your time.
