- Windsor, CO NEC: 2017
- Hospital Master Electrician
1.) NEC Section/Paragraph: 210.52
2.) Proposal Recommends: [new text]
3.) Proposal: Add the following to 210.52.
My reason is, my living room switched recep is totally switched--no half-hot. A receptacle does exist at the required spacing, hence it's compliant with 210.52.
(No, I'm not writing a proposal because the dude who wired my house is a putz.)
[ April 15, 2005, 08:24 AM: Message edited by: georgestolz ]
4.) Substantiation: Late for work, will write one.Receptacles in the areas defined in this section shall be permitted to be switched, provided uninterrupted receptacles are installed at the spacings required by this section.
