Scottybars2288
- South Carolina
- Electrician
Need to add 100 amp sub panel outdoors
Question- I have a 200 amp service outside, it's an old house so there is just a meter outside, with no disconnect, that goes inside the home to the main panel with SER.
I need to trench in a 100 amp sub panel on the pool house of the property. I'd like to somehow bug the load side of the meter, fuse down to 100 amps, then feed the pool house with pipe and wire obviously.
Is it suitable to bug inside of a meter can? (im assuming no but understand this can very from POCO to POCO) and if not, what is the best way to accomplish this
