I have a issue that I'm not quite sure how to handle. Have an existing 200 amp meter and will be added a 200 amp feed-thru panel and a 200 amp transfer switch for future generator. Will be going from meter thru the feed-thru to the ATS and then back to the feed-thru (separate conduit). Was going to reinstall the existing 200 amp panel to the feed-thru lugs. Contractor had run (2) sets of wires to the area where the feed-thru panel will be. One set is #2 direct burial for a single garage with a door opener and 2 lights and the other set is where I'm having a problem. They ran 4/0 direct burial 4 conductor for a dry cow barn with (2) 240 volt 2 hp fans and some led lights. #2 AL would have been an overkill as the barn would not have over 25-30 amps max. I don't have anywhere in the feed-thru panel for the 4/0 wire. Can any tap rules apply or conductor reducing pin or something similar?
