Urchinhead
- San Francisco, CA
I have done some work to correct various code violations at a four-unit building. The 4 units are split between two meters/two panels, and the only gec path is from one of the meters to a water pipe directly above it.
The owner would like me to add a grounding system for the existing service, and leave the two meter/two panel set-up for the time being. My only thought is that I can add a fused disconnect before the meter enclosures, and bond the service at the disconnect. I will then remove existing bonding at the meters, and run my gec path from the disconnect. This will also allow me to add a bank of four meters and panels in the future, without re-splicing the utility connection.
Many older buildings have a set-up just as this, where all bonding is performed at the main disconnect, before the meter banks. Is there anything that I should be concerned with, or is there a better solution that someone has in mind? By local code, the GEC must be protected, so I will run 1/2" EMT from the disconnect to the grounding rods and cold-water pipe.
