Adding a ground wire beside a 3 wire SEU cable?
Stevenfyeager
United States, Indiana
electrical contractor
A Home inspection revealed a 3 wire SEU cable (Cu)with a bare #6 solid wire (Cu) ran separately between an outside disconnect and inside house sub panel. Sub panels require 4 wire cable. The solid grd wire is not even run along side the SEU. This does not meet code even if it was done 40 years ago, correct?
Definitely a violation under todays Code and likely was at the time of installation but considering the age it might have been an accepted practice locally at one time. Interior runs of SEU (3 wire) with no outside disconnect were commonplace in this area at one time.
