Adding a knock-out
nizak
Does adding a knock-out to a panel void any type of warranty? What I've got is a 200A 3R main breaker panel that I need to get another entrance into. It currently comes with provisions for up to a 2 1/2" "B" type hub to be installed in the top, I am looking to add a 2" opening in the back and use a water tight hub. Thanks.
I opened a panel the other day and they came in (2" 200a) in the space above the main. Made for a very tight bend to land the wires, I think maybe they worked it from both ends. Did that myself with a meter socket, concentric KO just below the load lugs, back to back service, bent the wires and pushed in to the panel to land them.
