justfreeze
- Ohio
Background: An existing 480V power cable is already connected to a 50HP motor. Currently this 50HP motor is locked out at the starter. A request was made to install a local disconnect for this motor but around 100' away from the motor. The decision was to run a new cable directly to the new local disconnect from the starter and then downstream of the local disconnect to the 50HP motor.
My question: Why couldn't they just put a junction box where the existing motor cable is then run the new cable down to the disconnect and then back up to the motor since this is a shorter distance then running new? I have limited expereience regarding this, is it because it is not to code to install a junction box out in the field for 480V? If this is so can someone point me in the right direction regarding the article in NEC so I can read up on it?
