Ohms law
- Sioux Falls,SD
Would I have to add a outlet on a wall that was once a hallway now a living room wall? Iam only here to add can lights , arc fault protection and a four-way switch.
Took down two walls to make there living room longer. One wall of the bedroom was defined this area as a hallway now it's removed the hall way is now shorter, leaving a greater than two foot wall space. No walls are opened up and there are no plans to do so either.
For a situtation like this we just do the work and call in for inspection, then the inspector looks for proper AFCI protection and test the device that's about it.~ # ~ # ~
Ohms law,
When you applied for & obtained the permit from the local AHJ,
what did they say about your submitted plans or Scope of Work
for this project ? :huh:
So, if you just call for "can lights" the inspector will not inspect the remodeled area and will not ask about the missing receptacles?
Added:
IMO, a good inspector will ask for proper receptacle placement and for AFCI, even though you are installing can lights.
