scottgjerdingen
I am a homeowner seeking advise and hope you could help me out.
I recently put an ~ 500 gallon aquarium in my home. It is a saltwater tank and has enough equipment running off of it that I want to bring in 2 20 amp circuits just for it. My idea was to have a 60 amp sub brought over to the area where all of this is and have 2 20 amp lines run off of this. Also, because the saltwater fish and corals are delicate the cannot stand power outages I have a backup Generac generator (7500watt/13000watt surge) and I am looking to have this wired into the house as well via some sort of 60 amp transfer switch/circuit to the main.
It was alternatively suggested to me that this getting the 2 new circuits and wiring the generator such that electricity could be supplied to them in the event of an outage could be accomplished by installing a 60 amp "generator panel" that would have the 2 new 20 am circuits on it and would be connected to the generator (and there would be one open 20 amp slot to connect the furnace and maybe a refrigerator).
Personally I feel the second option 2 unrelated needs together via a single solution and doesn't address either need as best as possible. First, by running the circuits for the furnace and fridge into the 3rd 20 amp slot on the sub I have taken away the ability to open a 3rd 20 amp circuit for future aquarium demand. Second, given an outage situation the first option seems to provide me with the flexibility of selectively powering a variety of things (tv, lights, phone, ac?, furnace, etc.) as long as I was careful to keep below say a 60 amp draw on the generator. Given the second option, the only thing I could power via generator would be stuff wired into the generator panel (aquarium stuff, furnace and the fridge) and since in this situation my aquarium usage would be minimized (e.g. would not be running my 3000 amps of lighting) I would have excess generator capacity that I could not tap into w/o breaking out extension cords which then kinda defeats the purpose of wiring this into the house in the first place? I suppose there is merit to both options and one possible compromise is using one of those 8-10 circuit transfer switches that can be wired to specific circuits that I can turn on and off as needed...but I do think I am aware enough realize the when the generator is on demand should be kept to a reasonable minimum (e.g. no hair dryer, laundry, dishwasher, minimal things all on at the same time, etc.) and 60 amps is a fair amount of electricity for a smaller home).
So, can you possibly explain to me why the first option is bad and/or the second option is better and even better yet, can you specifically suggest the best method of accomplishing what I am driving at in option 1 (also, I am working on a budget and will need to get a professional that can do this for as much under $2,000 as possibe - I need to also fund an inverter to hold the aquarium over until I can get the generator started )
Thank-you in advance for your help and cooperation!
- scott -
- scott -
