Is there any way legally to add a transfer switch and generator to an already installed residential 200A panel? My buddy (another electrician) and I were trying to figure this out, but we work mainly on Industrial jobs and lack "the residential knowledge" and code. Also, he's trying to prevent pulling the meter or working on the line side of the 200A breaker.
This is his suggestion/plan:
You have your Meter Pan which feeds your panel. Now this may sound ludacris, but bear with me. Install a sub-panel next to your main and transfer all your branch circuits and breakers to this sub-panel which will have a 200A main breaker. Install a 200A 2P breaker in your Main Panel which now only contains your Main 200A Breaker/Disconnect. Run conduit/wires to a Transfer Sw (prob a MTS) from Main Panel and from Generator. Then run conduit/wires from Transfer Sw to new Sub-Panel.
New 2P 200A breaker will act as disconnect to transfer switch "normal" side. Main breaker on generator will be disc for transfer sw "emergency" side (unless a Disc Sw between the Gen & TS is required). You still have a means of disc in your Sub-Panel with a 200A main.
All sounds good to me, but as I stated already, I'm not up to the code on residential and he doesn't wish to work live or pull the meter.
If ANY of this is even legal, please let me know. Or, if anyone knows of a different approach, I'm all ears!
Thanks!
Thanks!
