- Bremerton, Washington
- Master Electrician
For an existing fire fire pump station, have a 100 HP electric and a 1500 gpm diesel fire pump. There are frequent power outages, causing the diesel fire pump (DFP) to run, the DFP has proved unreliable (broken shaft, overheated injectors). Proposal is to install a diesel generator so the DFP would not run in a outage.
Art 695 calls this a "on site standby generator"
Article 700 in Emergency Systems has an note that gives examples of emergency systems, which includes fire pumps.
So what type of generator will this be, Emergency, Legally Required Standby, Optional Standby?
It makes a huge difference on the installation requirements.
And would all the power wiring in the fire pump station, now powered from POCO, be required to be identified per 700.10 (A)?
Also the new requirement for an alternate source of power in 700.3(F) is challenging, look at this if you haven't in the 2017 NEC
