malachi constant
- Minneapolis
Hi all,
We have an install still under warranty where handholes are filling with water (which stands for a week). The spec calls for a gravel bed under the handhole but these were installed direct on earth. The Owner would like this corrected, so I plan to approach the contractor about fixing this and am curious about work effort / what means are required. I hope they can hand dig around it without disconnecting conduits and wires. FWIW the handholes are roughly 18"x36"x24" deep with 208 & 480 volt circuits. I didn't see any splices but there was quite a bit of cabling underwater and/or caked with mud which made it difficult to say for sure. Most if not all the handholes are not in an area prone to standing water - it should keep running off for a good distance.
Three questions here:
1) Will a gravel bed significantly mitigate the issue?
2) Any recommendations on size/depth of bed?
3) It's not really my problem, but what work effort would you expect here for the contractor to add the gravel after the fact?
Thanks!
Thanks!
