I have an out of doors residential hot tub that is going to be placed on a slab with a deck built around it. The plumber has suggested to the customer that a ground rod be driven for it. Would it be beneficial to add this supplementary ground rod to minimize touch potential or is the resistance too great to prove effective? I believe Mike has stated that grounding electrodes are only effective as a path for lightning. If this is the case,what supplementary bonding may help? Remember, this isn't a pool where I can bond the rebar before the concrete pour. Any suggestions would be appreciated.
