I am a new owner of a 1955 house who happens to be an electrical engineer, but by no means an electrician and I could use a little advice. I apologize in advance for the long post, but I want to be clear.
My house is a mixture of grounded and un-grounded branch circuits. The 15-Amp lighting circuit, which runs all through the attic, has 14-AWG two-wire NM cable (with no ground wire). I would like to add an equipment ground to some of the cases of the new fluorescent ceiling lights I have installed in the kitchen and laundry room.
I noticed that there is an uninsulated ground wire just freely running through my attic (it's not inside an NM cable; it looks like a fairly low-gauge copper ground wire made of two or three wires twisted together). It's looks pretty wimpy and all alone up there. This ground wire must somehow be connected to the ground wires from one of the circuits running in the walls or under the house, where there are grounded circuits. The prior owner must have done this when they remodeled the bathroom and needed to have a ground wire to connect to the new bathroom outlets (because that is where this ground wire is presently going).
So my question is, can (or should) I just connect another uninsulted copper "ground" wire to this existing one and run it over to my lighting fixtures in the attic? Ideally, I would like to just replace the entire lighting circuit with new NM cable all the way back to the service panel, but I am not certain how to "fish" the old NM cable going to the panel out and replace it with a new one. If I could just get a new NM cable from the panel to the attic, the rest would be easy to replace and clean up (the current cables are just strewn about through the attic without being properly stapled down and many of them are showing their age).
So,
1) Can I just connect the light cases to this existing ground wire from one of the other circuits in the house?
2) How difficult is it to add a new cable from the outside service panel running up through the wall and into the attick?
By the way, the urgency for wanting to ground the new fluorescent lighting cases is because it turns out that if you don't ground the cases, they emit some leakage radiation that produces about 60 volts AC between the case and ground (I see the 60 V if I connect one voltmeter probe to a screw on the light case and the other into the neutral or ground plug of an outlet that is on a separate grounded circuit). I talked to the ballast company and they said this is exactly what happens when you don't ground the case and that it is within the UL safety limits (i.e., if you touch the case and ground you will feel a buzz but you won't pass out). However, they told me I really need to ground the case because the ballast circuitry only functions properly when that ground is present.
Thanks in advance for any advice.
Michelle
So,
Michelle
