Adding house to existing 300 amp meter combo panel
frito
New User
Nc
Retired
I currently have 300 amp panel feeding camper and shop a house is now being added with 200 amp panel. The 300 amp panel needs to be replaced with vault to possibly move panel to house as this is in what will be front yard or can you tap 300 amp feed from power company in vault to feed a 200 amp meter base combo for house and 100 amp meter base for shop this house is in Utah any other ideas of handling this problem would be appreciated? Also power to house must pass over sewer line how much separation is required when using direct burial cable?
Before I allow anyone to respond, please tell us what your previous occupation was (i.e., before you retired). If you were not an electrician, then forum rules do not allow us to assist you. If you were an electrician, then please update your profile to say so (to prevent further delays).
