eplmisme
- bellevue wa
- signal electrical inspector
i am a signal electrician for a municipality. we are testing a new UPS system on our in house "bench" signal cabinet. in house we do not have enough load to represent our largest loads in the field. the cabinets draw around 2.5 amp at 120vac. i want to add 1.5 amps to our bench test. i was thinking the easiest way would be to add a 180ohm resistor in series to create an extra 1.5 amps. my question is would this be something that could damage the electronic components in the cabinet: controller, MMU, power supplies, ...?
plugging a load into the power strip inside the cabinet would be creating a parallel load and would not give the desired effect.
i know on DC circuits you can make a continuous current load with a mosfet and some other components. these are from what i can see only for lower voltage DC circuits.
any help would be great.
have a great day.
evan
have a great day.
evan
