buddyshuffle
A customer is looking to add electric ranges and electric dryers to existing units in a condominium building. The plan is to add a new panel at each floor of the building (each floor contains 9+ units) to allow for new feeds for ranges and dryers in each unit.
I've been working in 220.18 and 220.19 for load calcs, but with over 200 ranges and 200 dryers being added, I wondered if a better method could be used since Tables 220.19 & 220.18 stop far short of the 200 in both cases.
220.30 won't work because the exisiting dwelling units have only a 60A feeder which is less than the required 100A.
220.31 results in a larger estimate than 220.18/220.19 so this is also not acceptable
Any suggestions...Thanks!
