Kdog76
- The Dairyland State
Im trying to locate a 6 port bolt-on lug to replace a one spot lug on a old 400 amp Square D fusible disconnect. The disconnect feeds five panels, and all the feeders are terminated underneath the one set of lugs on the load side of the disco. Inspector would let me use a power conversion block, but changing out the lugs would be a lot easier. I believe it uses a 3/8" bolt, and wire size max. is about 2/0's I think. I would need two of them. I got my suppliers digging around but I thought you guys might have a lead on something like this.
