Adding neutral
frisbeeaddict
New User
Fl
Contractor
Hello,
Have an existing spa feeder panel that has 6/2 NMB coming in. Want to convert this panel so can supply GFI supported 120v and
need neutral for that I believe. The conduit is little tight and don't really want to re run new 6/3 for over 100' if dont have to. Question is can I use
some 10/2 and run a neutral on those conductors in parallel. Section of this is through an attic/outside of raceway or would use
THHN etc so need something sheathed I imagine. Thanks,
I am closing this thread, in accordance with the Forum rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
If I have misjudged the situation, if for example this project is related to your work, then send me a Private Message. If you can show me that I am wrong, and that you are a licensed electrician (or at least a licensed apprentice), then I will reopen your post, and offer an apology for the delay and inconvenience.
A reminder to all members, if you see a questionable post, feel free to report it by clicking the button at the bottom left corner of the post.
