dylanmitchell
- San Diego
- Historic (Old and outdated) Home Renovation
I'm feeding a new outlet from an existing 12/2 20 amp outlet and planning to use prefab quick ac whip 15 ft., 12/2 Solid CU MC to run power to the new outlet.
I have the ac whip, the ends measure just under 1 inch. What fitting and J box do I use?
AC whip will be run behind drywall, there's space for J box, surface mount receptacle will be mounted out another side of the drywall.
Parts
Have 15 ft., 12/2 Solid CU MC (Metal Clad) Armorlite Modular Assembly Quick Cable Whip by Southwire
Need J box, fittings, and anti short bushings
Have surface mount 1 gang box and 20 amp receptacle.
https://www.homedepot.com/b/Electrical-Wire-Armored-Cables/Southwire/N-5yc1vZ4mmZc57m
Thanks
Parts
Thanks
