pinkynbrain
New member
I've read Article 80.9(C) in the 2002 NEC. Where does responsibility end in the following situation: I'm adding circuits in numerous existing panels of multiple buildings. This may require 1)adding a breaker for the new circuit, 2) retrofitting the panel and/or repulling feeders to accomodate more circuits or load, or 3)completely replacing the panel in the same location -because a retrofit interior cannot be obtained for panels with the smaller cans-. When the panels do not already have a grounding electrode am I required to install one 1) upon adding ANY new circuits or wiring, 2) when changing the interior/feeders, or 3) only if I change out the complete panel with a new one. Is this a determination which can only be made by the 'authority having jurisdiction'? In replying, please mention any reference you may have used.
