The original plan to upgrade a service is now under further review.
A customer will be adding an immense spa/endless pool unit outside. 11KW/240V of electric heat, 40A/240V pumps for endless pool, and 50A/240V for the hydro-spa heat/pump. Do I figure this at continuous duty 125%, or just 100%. Or should a duty cycle be considered?Either way 140 amps of additional load is making me consider a 300 amp/ 240V service (install a 400 amp meter base capable of double lugging to create 2 taps for 150amp panelboards)
