Andres Arias
PV Solar engineer
 - New York
 - Electrical Engineer
Hello dear colleagues.
I have a main electrical panel with a PV string inverter system (OCPD: 25A) connected with line taps in the feeders. An additional PV system based on microinverters (OCPD: 30A located in an AC combiner) will be installed in the same electrical panel of the house. Is it correct to install this new sytem using line taps in the supply side of the electrical panel, given that there is another connection with line taps?. FYI, the main panel busbar rating is 100A and the main breaker is 100A as well, so the NEC705.12A is met:
OCPD(micros) + OCPD(string inverter) < busbar rating
(30 + 25) < 100 --> 55 < 100 then OK
Let me know your thoughts. Thank you
