Re: Addressable Fire Alarm Panel-Is it Worth It
I have discovered that I can probably afford the equipment and there is no design change schematically since the designer did not specify how to install the fire alarm detection system. That was left up to the construction contractor and I have time to change the designers costs for addressable material.
I estimate $80,000 to install an addressable fire alarm system in a 40,000 square foot two story building based on past information.
I estimate a conventional fire alarm detection panel to cost $6,000.
I am awaiting estimates for an addressable fire alarm detection panel and any increase in costs for the addressable notification devices or conventional notification devices with a mini monitor module installed (that makes them addressable).
My verdict is still out. If the addressable system is $40,000 more than the non addressable system for the building above, it could make sense, but is getting in the unafordable range.
I have learned that water sprinklers don't save equipment, just lives (they actually destroy equipment) since NFPA 72 is a life safety book not equipment safety book. We have automatic sprinklers in full and partial supply in this building.
It is not the goal of a fire detection system to save equipment, since the equipment will be destroyed anyway most likely during a fire, if not by the fire than by the automatic water sprinklers.
The cost/benifit ratio is for lifes as a matter of principal. There is also a cost/benefit ratio when life insurance dollars are included in to the equation, albeit the initial investment dollars are available.
