Neal30
- Gainesville, ga, USA
We are connecting an advanced energy 50 kw inverter to the utility. The commercial site has a
480V 3 phase 3 wire delta pole mounted transformer configuration. The inverter has a
480V 3 phase, four wire, wye output. Would we be able to connect into the utilities configuration as is, or would we need to use an isolation transformer?
http://solarenergy.advanced-energy.com/en/PVP35kW_50kW.html
Inverter spec sheet above.
I would appreciate any reference material you could recommend to verify either conclusion if at
all possible.
Thanks
all possible.
Thanks
