Obviously the ability to crimp connectors is expensive. There's tons of options with wide ranging prices, which are all pricey for a tool that isn't used a whole lot for a small operator.
I know I need the ability to use crimp connectors, possibly a stud lug for terminating in a panel enclosure, or a butt splice for adding length to a wire (maybe underground burn-off or similar).
Being a small operation I mostly work with wire 350 MCM and smaller (and mostly aluminum). I also would like to be able to crimp ground wire if I need to extend a GEC with an irreversible crimp.
Every time start researching the buying options I get overwhelmed with information.
Different tools handle different dies...
What types of dies do I need for the crimps I'll be doing...
Can those dies handle different brands of crimps... (Burndy versus Ilsco...)
Does one set of dies handle all brands of crimps (universal)...
Do I need a battery operated tool...
Could a hydraulic manual tool do the job, possibly saving money to put towards dies...
Etc..., etc..., etc...
I'm just a small operation and wouldn't use the setup often.
I can't see getting into this for less than ~$2,200. And could go up to $5,000.
That's a lot of coin for something I'll only use a few times a year.
I'm scared to go the eBay route and get used on an investment like this.
I know some will suggest going the rental route. I've looked into that and it doesn't seen to be available at the couple of SH's I have access to (I live in rural North Dakota). Also, if I were to do a service call on a weekend for an underground burn off I feel I should be "crimp ready" and not have to wait until Monday to get a tool.
Any advice for a small operator would be great.
Thanks!
Thanks!
