Since i just returned to residential electrical trade, I'd like a few pointers on grouping lighting and outlets circuits in new construction. I think I tend to over engineer, i.e. dedicating a circuit for bath fan/light/heater. Is there a general expectation for number of lights or ceiling fan/lights or outlets permissible on a single circuit? I cannot count the number of times I've had to add Outlet circuits in even newer homes because the contractor, even though within code, skimped on out let circuits. Thanks in advance for comments.
Sent from my SM-T713 using Tapatalk
A bathroom heater fan will require its own individual branch circuit per mfg instructions; 110.3(B). If the fan is unknown when you are roughing in, I'd pull a piece of ENT to the switchbox so if you need 5 conductors for a 4 function fan, you can pull them in easily.*
The way I do it is everything that needs its own circuit, like oven, dryer, water heater, HVAC, etc. get its, then group the rest as logically as possible. Holiday lighting may require AFCI and GFCI breakers if you have Sill-Lites or the like in bedrooms and garage windows.
Running a spare 12/3 and 14/3 to a j-box in the attic and crawlspace each gives you 8 more 15/20A circuits. 4 2 gang jboxes and 40' of wire is very cheap and great insurance for future use, especially if the panel will be hard to get at. Those length wires are basically scraps anyway. *One of these can go to the bathroom fan if it's a heated type that needs its own circuit. You may also want to stub down from the panel a 1" and 1.25-1.5" ENT for future use needing larger wires, like a spa, workshop, subpanel, or genset. All of that may take an hour labor and cost $40 in materials, which will more than pay for itself if anything is added in the future, just on reduced labor not having to fish wires in the panel.
As of now, VA is still on the 2012 IRC for residential electrical, so AFCI on bedroom outlets only. If there are substantial changes in the 2015 re: AFCI req's, grouping outlets and receptacles tighter will yield a less expensive install, but for now, another $4-9 breaker isnt a budget buster.
Running a chase or two for comm wires from attic to basement is also a good idea. Much cheaper to install a few sticks of conduit than to tear up finished walls later to fish them in.
Lastly, certain circuits seem to get overloaded more quickly than others when additions are made. The lighting circuit for the entry area is one, say the customer wants outdoor driveway lights or a nice chandelier with 25 40W bulbs, it wont happen w/o a new circuit if the original is loaded to bear.
The spare circuits allow me to load more on the working circuits and use less of them since I know I can easily wire up anything the customer would want in the future.
