winslowfam
- VA
hi...our client needs a 480 volt feeder from their main plant building to a rack-mounted panelboard that will provide power for local various loads. The feeder to this new panelboard will be installed from a service mast/head on the outside wall of the building to a new pole located next to the new panelboard, 100 feet away, with another service head at the rack. The space between the building and the panelboard is an un-used open field, with no activity or build-up ever planned for that area. I am having a hard time figuring out how much clearance above grade is required for this feeder at each end, and how high the service heads need to be at each end.
