I have a 200amp main service entering the primary residence. This property also has a small dwelling approximately 50ft away that was originally fed by a 2wire old bx fed thru a cast drain pipe. We need to intsall EMON metering equipment at the small dwelling and replace the existing fuse panel.
My intentions are to remove existing bx cable. Run new 100AMP SER from main panel ==> outside and up building. Then run a quadplex aerial (since I need to isolate the neutral from the ECG since this installation, i believe, should be treated as a subpanel) to the small building, then down the small builder with SER.
Is this an acceptable installation (I'm getting mixed results from my peers), or may someone suggest an alternate safe installation.
FYI, the ground is almost all rock and digging is really not an option.
Thanks
Thanks
