Re: AFCI and GFCI, what's the differance?
The following discussion does not represent the ?exact truth.? But it does have some truth in it, and it should help you understand the difference between the two devices.
The rules of electrical science require a complete path ? electrons that leave the source must return to the source. Every time an electron moves up the ?hot wire,? another electron is supposed to be retuning via the ?neutral.? (If anyone is familiar with the lack of precision in these terms, please ignore them.) If some don?t make it back via the neutral, then they had to have made their way back to the source by some other path. That other path is likely to include (1) Metal things that ought not to be energized, (2) Planet Earth, and (3) An unwary human. When current follows such a path, it is called a ground fault. A GFCI measures current on both legs. If it sees more current going out then going in, it trips, just on the odd chance that there might be a human in the current path.
An arc is the passage of current through air (not generally considered a good thing). A frayed wire in an extension cord is a frequent cause of such an arc. Sometimes the frayed tips of the wire mate, and can carry normal current. Sometimes they part, and interrupt current flow. An arc is drawn as the tips just barely separate, or just before they come once again into contact. If it is timed just right (or I should say, ?just wrong?), the ?on again off again? pattern can cause voltage to increase far above normal levels. The wire gets far hotter then normal, and can start a fire. An AFCI device is designed to trip when it recognizes the ?on again off again? pattern of current flow.
