Yes, afci and gfci work fine together. I am not sure what you mean by what is the setup. In fact most AFCI have ground fault protection in them-- not enough to protect for personnel.
Thanks what I meant was, for example a 120v ltg/recept ckt,,,,,,,,,,,,would it be an AFCI bkr at the panel and a GFCI receptacle in the area where used or what.
dick
Is arc fault required for lighting in kitchen? As well as low voltage uc lights?
